Excel component not working Mathcad Prime 3.0
efontana
Excel componente is disabled in my Mathcad Prime 3.0. Has anyone experienced this problem? In any possible way I try to use this feature it does not become enabled for me to test.
Any comment will be welcome.
reg
(To:efontana)
Strange - this usually only happens if the cursor is inside a region and not on a free space in the sheet. Is this the case?
Which version of Excel do you have installed?
From the help: "To work with an Excel component, you must have Excel 2003 or later installed." But I guess this shouldn't be a problem nowadays.
13 REPLIES 13
(To:efontana)
Do you see this?
This would mean that you have no valid license and your trial period is over - you are using Prime Express.
In the full version it should look like this
and if you click Insert... you get a template like this
In Express you should still be able to use READEXCEL() and WRITEEXCEL().
Hi Werner, is not this problem. I have a full academic licence and it is fully functional, i..e, there is no locker in the excel or any other button of my interface. In my version, when I click on the Excel Component all items in the dropdown menu are grayed, i.e., disabled.
This is how it looks like
(To:efontana)
It might be that. I have a special excel (MS Excel starter 2010). Would this be the reason? Maybe I have to instal the full office package for the excel feature to work.
(To:efontana)
I am not sure. I would have guessed that starter 2010 should suffice.
VladimirN
(To:efontana)
You need to upgrade from "Starter" version to higher. Mathcad/Mathcad Prime does not work with MS Office Starter.
(To:VladimirN)
Good to know. Is this documented somewhere?
VladimirN
(To:Werner_E)
No. This is my experience.
the cursor is not in any special region, by the way.
(To:efontana)
So I may suggest to contact PTC support.
[EDIT] which now should not be necessary accoring to Vladimir's post above.
I bought office 365 and after installing it the excel component worked. Thanks all you guys for your inputs.
(To:efontana)
It should definitely be documented by PTC that the Starter edition doesn't work with Prime!
