Exit While problem
Raiko
Exit While problem
Hello all,
I don't understand what's wrong with my code. I use it in a textbox and get an error notification from the editor (see attached pic).
The code (in my eyes) is straight forward and should compute.
ni=0
While M(ni) < d88
ni=ni+1
If ni > N Then
Exit While
End If
Wend
Can anybody help?
Raiko
P.S.
The message below says that a compilation error was encountered and a "sub" was expected
StuartBruff
(To:Raiko)
On 11/26/2009 7:56:47 AM, raiko01 wrote:
== I don't understand what's wrong with my code. I
== The code (in my eyes) is straight forward and
should compute.
== ni=0
== While M(ni) < d88
== ni=ni+1
== If ni > N Then
== Exit While
== End If
== Wend
I don't think there is an 'Exit While' in
VBScript.
The following might do what you want:
Do While M(ni) < d88
ni=ni+1
If ni > N Then
Exit Do
End If
Loop
Stuart
Raiko
(To:StuartBruff)
Thank you Stuart, you made my day!
And you're right. There doesn't seem to be an Exit While in VB script.
Raiko
