Explicit function definition
ptc-4457992
I am quite new to Mathcad. What I want to do is to define a function explicitly (i.e., as pairs of x - y or x - f(x) values), not analitically (through a formula). Does anyone know wether that is possible or not? I am using Mathcad 14 and I searched the user guide, provided examples and tutorials, but couldn't find anything related to this subject. I even tried to do that myself, by improvising, but without any success.
Moreover, if it's possible to define a function explicitly, could one calculate definite integrals on it afterwards? (I know that is easy if the function is defined analitically).
Best regards,
Marius
9 REPLIES 9
Yes I believe it is possible, but I'm not sure exactly what your after.
Could you provide an example and post the worksheet?
Mike
Hello!
Thank you for your answer. I don’t have a worksheet yet, but here is what I want to do (I simplified the problem a bit). I have the following (x y) data set where y represents the value of the derivate function at point x:
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
What I want is to get the value of the function, by numerical integration, at these x points. I don’t need any curve fitting, interpolation function or any other kind of approximation. Could you give me some hints on how to solve this problem with Mathcad?
Hello!
Provide a screenshot of what you want.
Hello!
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
Given an x,y data set there are several ways to proceed; the choice depends on the data and what you want to do. With a dense and complete data set you can use numerical integration techniques. You can curve fit the data--find a function that approximates the data closely, and use the built-in integration schemes for manipulation.
Hello!
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
RichardJ
(To:ptc-4457992)
You need to create an interpolating function. The most general solution is a cubic spline, but it's not always appropriate. Without seeing the data it's hard to say much more.
Hello!
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
RichardJ
(To:ptc-4457992)
We don't need the same reply four times. It's just as easy to read one reply four times as it is to read four replies
All numerical integration is approximate. The attached is a very general, and usually accurate, approach.
