I am quite new to Mathcad. What I want to do is to define a function explicitly (i.e., as pairs of x - y or x - f(x) values), not analitically (through a formula). Does anyone know wether that is possible or not? I am using Mathcad 14 and I searched the user guide, provided examples and tutorials, but couldn't find anything related to this subject. I even tried to do that myself, by improvising, but without any success.
Moreover, if it's possible to define a function explicitly, could one calculate definite integrals on it afterwards? (I know that is easy if the function is defined analitically).
Best regards,
Marius
Yes I believe it is possible, but I'm not sure exactly what your after.
Could you provide an example and post the worksheet?
Mike
Hello!
Thank you for your answer. I don’t have a worksheet yet, but here is what I want to do (I simplified the problem a bit). I have the following (x y) data set where y represents the value of the derivate function at point x:
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
What I want is to get the value of the function, by numerical integration, at these x points. I don’t need any curve fitting, interpolation function or any other kind of approximation. Could you give me some hints on how to solve this problem with Mathcad?
Hello!
Provide a screenshot of what you want.
Hello!
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
Given an x,y data set there are several ways to proceed; the choice depends on the data and what you want to do. With a dense and complete data set you can use numerical integration techniques. You can curve fit the data--find a function that approximates the data closely, and use the built-in integration schemes for manipulation.
Hello!
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
You need to create an interpolating function. The most general solution is a cubic spline, but it's not always appropriate. Without seeing the data it's hard to say much more.
Hello!
X Y
0 0
0.2 0.1987
0.4 0.3894
0.6 0.5646
0.8 0.7174
1 0.8415
1.2 0.932
1.4 0.9854
1.5708 1
We don't need the same reply four times. It's just as easy to read one reply four times as it is to read four replies ![]()
All numerical integration is approximate. The attached is a very general, and usually accurate, approach.
