See attached pdf. X and Y axis both have the same scale / range 0 - 9350
When displayed in mathCAD Prime 4.0 only hte x axis is formatted 0- 9350
Why does printing / exporting change the plot axis??
Adam
Hi!
It depends from the resolution of the x-axis.
I changed from 0.1mm to 1mm and the plots will be fine at the pdf.
I think, the resolution of 0.1mm result in too many steps for plotting the functions.
(The graph seems to be not smooth)
Hope the attached files help.
Hi!
