Extra digits?
IRstuff
3-Visitor
Extra digits?
MP1 shows up with 2 extra digits of precision over M11, but where did that come from? Did they change the floating point format?
Also, pi and e appear to be off by 1 in the last digit.
TTFN,
Eden
Eden,
The floating point did not change, but I can check on the details. The last digit difference is from rounding. This came up in the Alpha test.
Mona
IRstuff
3-Visitor
(To:mzeftel)
Actually, there's an error in the display routine, between full precision decimal and scientific.
This is asin(0.5) with the different display modes
(* 5.2359877559829888 (^ 10 (@NEG 1)))
0.52359877559829893
Depending on which display mode is called out, the displayed precision is different, and, in the case of fixed point, erroneously displayed
the "correct" value from M11 symbolic engine:
.52359877559829887308
TTFN,
Eden
Eden,
I logged it.
Mona
It will be very very good to format not digits number after decimal point but common digits number in the numerical answer. See our discuss on this subject.
One engineering task -
http://twt.mpei.ac.ru/MCS/Worksheets/WSP/VPT-SI.xmcd
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
