The message you are trying to access is permanently deleted.
I have an array with values and I want to extract the rows, from a different matrix, that correspond to the values of the array. Any ideas on how that is possible? Right now the row extraction command (CRTL+SHIFT+r) will only accept integers.
Thank you in advance
To select an integer, klick on it. That is the standard Microsoft answer.
From where would you want to select an integer. You show a number of pictures, with several structures that contain integers.
I still think that your task is (the same as what is) explained, and solved, in this thread: https://community.ptc.com/t5/Mathcad/Retrive-horizontal-matrix-rows-based-on-vector-in-Mathcad/m-p/797732#M201303
For you convenience I've translated Stuart's worksheet to Prime6, so you should be able to load it.
Did you look at it? Does it meet your needs? If not, then as Werner already indicated: explain clearly, by a simple example, what you do need.
Preferably attach that simple example as a Prime Worksheet, NOT just a picture.
Can you provide an example for more clarity?
Cheers
Terry
Hi, I have a series of loads from load combinations that are placed on my model. I export those forces into excel and then bring them into MathCAD as an array. Right now, I check by hand, what I think will be the limiting factors, run the calculations for those scenarios and then see what it returns. What I want to do is run all load combination calculations at once and have MathCAD tell me which load combination(s) are the limiting factor(s).
Still not clear for me what exactly this should mean.
Maybe you would be better off if you provide one or two specific numerical examples, each showing the matrix, the vector AND the result you would like to see.
Hi Werner,
Each force is associated with a Load Combination (string). I want to know which Load Combinations cause the system to fail. I attached snaps of my worksheet below.
"Right now the row extraction command (CRTL+SHIFT+r) will only accept integers."
And that is for good reasons. Rows and columns of arrays are numbered sequentially, similar to platforms on a train station. As there is no platform 9¾ on London's Kings Cross station (except of course if you're a wizard), there is no row 3.14 in an array between rows 3 and 4..
Is your problem related, or similar, to this: https://community.ptc.com/t5/Mathcad/Retrive-horizontal-matrix-rows-based-on-vector-in-Mathcad/m-p/797732#M201303 ?
Hi LucMeekes,
I have PTC Prime 6.0 so I can't see the file but thank you for your help, much appreciated! I was wondering if you could perhaps explain the function? I am new(er) to MathCAD and was hoping you could guide me through on what you did.
If not, I understand but thank you once again.
The file was saved from Prime 6, so it should open in Prime 6 without problems. If it doesn't, let me know.
The function treats the values in the vector l as a list of row indexes. When an index is an integer number, it will fetch that row from the matrix M. If the index contains a fractional part, it will take the weighted average between two rows, as weighted by the fractional part.
So for 0.5 you get the average of (the values of) row 0 and row 1.
HI LucMeekes,
Thank you for the explanation! If I wanted to select a integer from this, how would I do that?
I am not sure what your function "Exctract" is supposed to do and unfortunately you don't show the error message which is thrown when you call "Exctract".
So just some remarks:
"match" returns indices and these always are integers. This means that your vector "Fail" consists of all integers and therefore "Fail.i" is always the very same as "floor(Fail.i)".
This means that "(Fail.i - floor(Fail.i))" simplifies to zero and your "if" condition has no effect as you always would get the row with number Fail.i of vector "vx".
I guess that the functions fails because of an index out of range?
I also don't understand the condition in your "if" statement:
if (Fail.i>=ORIGIN+rows(vx)-1, ....)
which, as I see it, is equivalent to
if (Fail.i = last(vx),...)
because no value in "Fail" can be larger than the last index of vector "vx".
Looks like you simply used Luc's function without understanding what it actually does.
Its still unclear to me what actually you want to achieve!
And, as Luc already said, don't post only pics but post the worksheet as well. If for some reason you are not allowed to post the sheet you may create a simplified stripped down dummy sheet with dummy data which shows the problem and state clearly what exactly you are looking for.
If you are looking for a vector of strings which only show which Load combinations failed, you may use
A shorter version is
Hi Werner and Luc,
Thank you all very much for the help. I was able to solve the issue by taking the MathCAD file that LucMeekes linked and adjusting it a little for my purposes. I have noted it as the solution. I am not very good at MathCAD (or coding in general) and have been trying to use it more and learn. Next time Ill be sure to upload a copy of the MathCAD sheet when I need help.
Thank you both again for the help.
