Extracting Rows Based on Array Values
FredLusk
As per the original Post..
Luc…
This is very interesting and elegant.  It turns out that I have an application for your method as well.  However, I have Prime 5 and can't read your Prime 6 file, and the image you posted is cropped on the right end.  Could you post a full image so I can recreate your solution in Prime 5?  Thanks.
Fred
LucMeekes
(To:FredLusk)
Sorry, that was a Prime 6 file. Now it is saved by Prime 4.
LucMeekes
(To:FredLusk)
Hi Fred,
Here's a compatible version for you.
FredLusk
(To:LucMeekes)
Luc…
Thanks, but I still can't read it.  I have Prime 5.0.0.0 and when I attempt to load your worksheet, I get an error message that says that this file "is from a more recent version of Mathcad."
Fred
LucMeekes
(To:FredLusk)
FredLusk
(To:LucMeekes)
Thanks, Luc.  Now it works.
