Extracting definitions from formulas in mathcad 15.
slaigaard
Hi
I'm using Mathcad 15 for solving the tasks given to me on my education as a marine engineer. Unfortunately, some of my teachers are rather "old-school" and does not accept the typical calculations with defined values in mathcad like: a = b + c = 5.
Does anyone know if its possible to make Mathcad 15 show the defined values in a calculation like: a = b + c = 2 + 3 = 5 ??? Also when using units like kW, Volts, Amps, ect.?
Please excuse my bad english
Simon
(To:slaigaard)
There is limited support for what you a trying to achieve if you use symbolic evaluation with "explicit".
Your answer was very helpful !
I've just tested it with some of my previous projects, and it seems to work on MOST of the cases! I'm a happy man, thank you
(To:slaigaard)
Glad that it worked for you.
The limits are when function calls are involved as explicit won't resolve them.
Simon
No problem :
With explicit:
