Extracting several matrices from program
MortezaA
I wrote a program in the mathcad for the first time , the program creates a few matrixes and vectors . which are unfortunately not equal in size , therefore can't be augmented .
is there any way i can extract them all out in seperate matrixes from the program?
Morteza Adinehnia wrote:
Thank you for your answer
I'm hoping to be able to extract Nnucl , r, time, C, sat, Mconsumed and Mstart all at the same time.
You can have a matrix of matrices, not all the same size.
(To:MortezaA)
Yes, but you would have to attach your worksheet and specify moredetailed what you want to achiev.
You might want to lookup the command "submatrix()" in the help.
(To:MortezaA)
Look if the attached would help. The program now returns a nested vector consisting of all the variables you demanded. I assigned it a vector with appropriate variables as this seems more natural for me, but you may still assign it a single variable U and can then extract the single components using the vector index, e.g. r:=U[1, etc.
Thank you
It was exactly what I needed.
