On 5/20/2009 8:48:47 PM, Heavenly130 wrote:
>I need to manipulate an earthquake signal.
==> you have an earthquake signal,
>I have a �target� signal
==> you have a target signal,
>... in the form of an acceleration time history.
==> in the form of an acceleration history,
==> then what ?
>I am using a finite element model (FEM)
==> you are using an FEM, OK ! and what does that do ?
,,, what it means is that you better have a work sheet c/w an abstract where the work sheet steps can be followed from the abstract. A discours that does not "print in the mind", does not print interest. It sounds simple with culprits, then make sure you save for the largest possible audience at least as low as version 8. If it does not work, that's because something wrong with your version. Fourier is as old as himself even in the very early Mathcad versions.
Lots of collabs contribute so much that finally they are short if time.
jmG
