Filter numbers out of the vector according to some condition
ptc-4697137
For MathCAD 15.0, is there any convenient way in MathCAD to filter the numbers outside of the specified range away from the vector?
e.g.
X=(-0.344 0.344 -1.056, 1.056)
but I only want answer within the range of 0.45<X<2
So the correct answer and only answer should remain is X=1.056 in this case.
I know there's the assume and RealRange(min,max) functions, but I'm not sure if it can be applied here. If so, how does it work?
Please advice.
You could do it like this:
However, since the end result is numerical you are better off solving numerically from the off, as in your other thread.
Alan
