Filtering data table to generate data vector
rcallisaya
If i have the "cBord" table, how can i generate a vector "qv", using some data colums of every table row? . The file in mathcad 15 is attached.
Thanks.
(To:Werner_E)
Or do you have something like this in mind?
(To:rcallisaya)
"Some data columns"???
Which columns?
The vector qv you define does NOT consist of some data columns of the matrix cBoard!
You can create a vector built from data columns of the matrix cBord using the "stack" command and the column selector
(To:Werner_E)
Thanks Werner_E.
