Find Definition Problem
Raiko
hello Folks,
the first MC15 sheet (find_1) has a solve-block which doesn't compute. The second (find_2), with a slightly different definition, however does. Can anybody explain why this is the case?
Tanks in advance
Raiko
(To:Raiko)
Mathcad is complaining that f(x) (and g(x)) ist not defined and thats true. How could the algorithm play around with x so that f(x)=x^2 or  f(x)=h(x), when it cannot evaluate f(x)?
You have to define your functions using the definition operator ":=", not the boolean "=".
And normally you would do this outside of the solve block.
(To:Raiko)
Raiko
(To:Werner_E)
Thank you Werner.
I knew that it had to be my fault 😉
Raiko
