Find Function
ptc-2315322
Find Function
please help to solve using the find function.
regards
prabhakaran
See if the attached helps.
Alan
Check the units of the RHS of the fy/Ed equation. The first term is dimensionless; the second term has units of Pa^-1 because of the Ed in the denominator.
Alan
The LHS of the equation Alan is referring to should be Jacob_pcr/Ed; check the image equation to the right.
sorry i made a mistake.
but i try to find alpha, beta for different thickness (alpha and beta are not constant for all thickness)
pcr also varies with different alpha, beta for different thickness
Alan
(To:ptc-2315322)
Find will find variables but not functions. You have defined alpha mad beta as constant functions!
