Finding the Minimun and Marking.
lvl107
20-Turquoise
I have a similar small question and also need help. (Please "Save As" to MC12).
Finding the (unique) Minimun and Marking. (like as above)
Thanks in advance.
Regards, -LL-
Something like the attached?
The functions are not dependant on both matrices.
Mike
Message was edited by: Mike Armstrong - worksheet updated
8 REPLIES 8
Are you wanting to show the min and max comparing both matrices or for each array?
Mike
lvl107
20-Turquoise
(To:MikeArmstrong)
Mike, searching through both matrix. (and NOT for each array). And the Output like as above. (This's only my intuition). And the max for option.
Loi.
Mike
lvl107
20-Turquoise
(To:MikeArmstrong)
Mike, you're right. My intuition was failed. And I have learned a lot from your comment and your worksheet.
Thanks for your time.
Regards, -LL-
No problem at all.
I have re-wrote both functions so they iterate through both matrices. There are pre-defined functions within the program, but I don't see that as an issue. Maybe someone else (betteprogrammer) can write a more efficient version - my bed time now
One last thing - it doesn't handle multiple min and max values. It will only indicate the first value found.
Mike
No problem at all.
Here's a variant, based upon the use of a common function, that will mark multiple occurences of the same value ...
Stuart
Nice neat function. I was trying for ages to get something similar to work, with no avail.
I wouldn't say its a variant though - more of a replacement.
Cheers
Mike
Slight variation of Stuart's function. Will now look through both matrices.
Mike
