Formula for matrix production
Ivan_Pat
Hi there!
I have an issue with the definition of the Prime user function.
There are several matrices 2*2 in the general case ( the exact matrix number oscillates from 1 to 4-5-6).
Each matrix has a lowercase index (connected to the data from the parameters table). I want to define user function to make matrix production. Due to my modest coding skills, I have no results to describe as appropriate. The relevant search on the forum gave some material but didn't seem to help.
https://community.ptc.com/t5/Mathcad/Production-of-Matrices-Elements/m-p/676964
In the attachment, there is my problem sample, performed in Prime 10.0.0
Any assistance would be appreciated!
LucMeekes
(To:Ivan_Pat)
This also works:
7 REPLIES 7
LucMeekes
(To:Ivan_Pat)
Try this:
Ivan_Pat
(To:LucMeekes)
@LucMeekes
Thanks, but this is beyond my level of understanding...🙈
By the way, paid attention to the similarity to the IF condition in my second reply...
ttokoro
(To:Ivan_Pat)
Ivan_Pat
(To:ttokoro)
@ttokoro Thank you for such an elegant piece of code solution!
Ivan_Pat
(To:LucMeekes)
Thank you for your support and understanding dear Luc. I just want to know, why I cannot see this post at PC after you picked a picture of how matrix product could be programmable solved.
I reply from my cellphone.
LucMeekes
(To:Ivan_Pat)
This also works:
Ivan_Pat
(To:LucMeekes)
@LucMeekes Thank you, it helped!
I modified your code with the IF condition a little for A=1.
