Hello!
I am trying to write this formula:
It uses the previous result (i-1) to calculate the next result (i).
How should it be written in mathcad? Right now I get an overflow or infinite recursion error.
It's no problem to define a recursive function in Mathcad, but you have to provide a starting value.
In your case: Where does i start, and what is the corresponding Ts,i value ?
Be sure to attach your worksheet, that'll help us better to help you.
Thank you, I got it working! Recursive functions was what I was looking for. Although mathcad seems to get very slow when calculating recursive functions. For i=20, it takes around 10 seconds to calculate it, but at i=25 it already takes over a minute.
I suspect that this sure could be speeded up significantly.
Ts.,i-1 occurs twice in your formula and I guess you are calling the recursive function twice, which could be avoided by either rearranging the formula so T.s,i-1 occurs just once or by calculating it once in the function and store it in a variable.
Furthermore I suspect that T.g is provided as a vector of values and you are looking for the vector T.s and not for a generic function to calculate arbitrary T.s values. If thats true, the calculation should/could be done significantly faster as no recursion down to the first value is necessary.
But without seeing a´what exactly you do and need its hard to say more.
Following up on Werner's comment, the structure of your problem is near (for values of near) to the Fibonacci recursively-defined function and is a classic example of exponential calculation times when "naively" implemented. The following screenshots (Mathcad Express 7.0) illustrate the problem.
Range Variable
Literal Recursive Implementation
(Added later): The reason that this happens is that at each call of fib, it calls fib recursively twice, first for f(n-1) and then for fib(n-2). In doing so, it makes no use of previous calculations, so fib(n-2) is called twice, once by fib(n) and once by fib(n-1). In turn each of these calls to fib also leads to two calls (until it hits the base case)). Consequently, the number of calls grows roughly as the power of 2 - (Ο(((1+√5)/2)ⁿ) or about O(1.618ⁿ) to be a little more exact).
Accumulating Recursvive Implementation
Stuart
