Function Evaluation
ptc-3137720
Function Evaluation
Good day everyone. I'm new to Mathcad, and I need your help. I have this problem involving a function evaluation. Let's say F is a function of multiple variables, and each variable has a discrete number of values. For example: F(a,b,c)=(a+b)/c and a={1,2,3) b={3,5,6) and c={8,9,7} In my problem, F is a function of 7 variables. Using mathcad, how will I be able to solve all the possible F values? this could be easily done manually for a small number of combinations, but how about for large numbers of possible combinations. thank you very much!
8 REPLIES 8
RichardJ
(To:ptc-3137720)
You need to use a small program with nested loops. Richard
StuartBruff
(To:RichardJ)
"Stuart Bruff" wrote:
As an alternative to using nested for loops, you could use an iterator to create each combination of values. Stuart (Works in M14, but for some reason that I am too tired to fathom out, M11 doesn't like the final for loop assignment).
RichardJ
(To:StuartBruff)
StuartBruff
(To:RichardJ)
RichardJ
(To:StuartBruff)
But, but, but .. nested loops lack Elegance. I tell you, the world's going to the dogs!
StuartBruff
(To:RichardJ)
