Hi
I couldn't understand why the function with condition statement in this case IF statement as shown below dose not work properly
Is this right way ? or I am making some mistake.
BR,
J.Randeep
P:S
On the other hand if i just use Maximize or Minimize manually according to the condition with out any condition statement it works correctly
I think it is a bug in Mathcad 15. In Prime OK:
Hi
Thanks for your insight.
Unfortunately I am using Math CAD 15 I need to find a solution that works with it.
If you are certain it is a bug, Math CAD support team should be notified about this?
J.Randeep
J.Randeep
It is not a bug. It is one methodology of the soft.
If(a=b, m, kg) - a bug in Mathcad 15 but not in Prime.
Can you use in your case y(x) or -y(x) for the finding min or max?
Here's a workaround in M15:
Alan.
Yes it did work.
But the logic is quite complex, it should be simple as Valery was mention it works fine in Math CAD Prime.
Thanks for your help.
J.Randeep
