How to Create a Math CAD Reference sheet
rjaison
I made a separate Math CAD sheet where I have wrote a function
Now I am trying to insert this sheet into my main calculation sheet as Insert--------> Reference
So that I can recall that function
But it is not working.
Any ideas!
BR,
J.Randeep
rjaison
(To:rjaison)
PS I have attached the sheet which I am trying to use as my reference sheet
Raiko
(To:rjaison)
Hello Randeep,
actually it is quite easy.
  1. save youre source sheet, the one with the function, you'd like to reuse at some convenient place. It has to be a function i.e.; it needs to have the form f(x):=... as you did in you frunction Circle(i,D,z)=
  2. in you target sheet, the one that likes to reuse the function, click "Reference..." in the >Insert< menu. A dialog box opens.
  3. Click the "Browse" button and navigate to your source sheet. Click ok.
    • Avoid the "Use relative path for reference" as you need to ensure a certain storage structure.
You're done. The target sheet calls up the source sheet function and all variables on it.
Cheers
Raiko
