Good Afternoon MathCAD User / Attention Valery,
This is to inform you that the worksheet that you are helping me with did not generate the right Matrix output.Please see attached. The correct matrix is shown at the bottom page of the worksheet as a pasted copy.
Moses
Hi Olubukola. Just correct the formula for the y[1,j], with sin instead cos and get the same result than the picture that you paste in the workseet.
Best regards.
Alvaro.
Hi O. A.,
At first fairly in-depth analysis, I would say that you should check all formulas ....
Bye
FM
Thank you all foryour help
Best regards.
Alvaro.
Thank you Mr. Diaz.
Moses
