You need two more equations. Otherwise you may chose two variables freely and can calculate the third.
The questions doesn't seem to make much sense.
May be so:
Hello, again.
Thanks in advance for your time and help.
Best Regards.
You should remember from former questions of yours that Mathcad's Find won't work with indexed variables!
Can you further explain what you are trying to do at the end? What are all this calculations for?
It works if you try reciproke values.
Whats that all about?
Many thanks, Werner.![]()
Best Regards.
That way you changed your vector X.
I had something like this in mind
Hello, again.
And related question :
Best Regards.
Whats considered as "simple" and maximal simplified might differ depending on the purpose.
Whats the purpose and the end goal in this case? There might be a way to achieve the end goal without splitting those expressions in sums of fractions.
E.g. it would be easy to write a recursive function to produce all your expressions q, Q, etc.
