Given/Find command, variable not defined
jpromol
Hi all,
I'm trying to solve a system of equations of motion using the given and find commands in Matlab.
However I get a variable undifined error on the find command and I cannot figure out why.
See the attached worksheet for my attempt.
Can anyone figure out what I'm doing wrong?
AlanStevens
(To:jpromol)
Fi is your problem. You've written it as though it's another component of F, along with F1, F2 etc.. If this was intended then i needs to be a pre-specified integer.
Alan
AlanStevens
(To:jpromol)
Alan
Thank you!
You're right I can't belief I've not seen this myself...
It works now.
