Given / Find function not working
jappelman
Dear readers,
I'm having a problem with MathCAD 15 to calculate forces.
I need 15 variabels (Fay Fax Faz, Fby Fbx Fbz, Fcy Fcx Fcz, Fdy Fdx Fdz, Fmmpy Fmmpx Fmmpz) and had 21 formulas. I red somewhere that it had to be 15 formulaes for 15 variables.
So i managed to get rid of 6 formulas.
Still undefined when i try to use the "find" function.
Hope someone can help.
Jeroen
10 REPLIES 10
Raiko
(To:jappelman)
when using the error tracing tool (Right-click on solution and choose "Trace Error") it says that your variable Rbdx (among others) is not defined. These need to be defined as starting values.
Good luck
Raiko
-MFra-
(To:jappelman)
Hi Jeroen
are missing some initial guesses
Thanks both for the very fast reaction!
I can't work on it right now, probably sunday.
I will check everything like you both said.
Thanks!
Still having a lot of problems with the answers.
For now, I Need:
F.mmpy = 190,2558 [N]
F.mmpx = 0 [N]
F.mmpz = 0 [N]
F.ay=F.by=F.cy=F.dy=F.mmpy/4
R.acx=R.bdx=0.05029 [m]
R.ay=R.by=0.378501 [m]
R.cy=R.dy=0.205599 [m]
Can't share my current file in this text..
-MFra-
(To:jappelman)
Hi Jeroen,
You can get what you want by entering in the Solve Block the conditions to be satisfied by the system.
To have a solution you have to change the initial estimates until you get a solution (which is not easy).
I added after the Solve Block the same equation for verification. See Attachment.
I've started all over again because I couldn't get it working correctly.
I hope someone can help me because my deadline is friday...
Regards
1. You have 12 equations and 8 unknowns!
2. Your system is linear. Use please the lsolve function! See please Given/Find and lsolve for one problem here 17.15 and 17.16 here Study 17. Cogeneration (CHP), trigeneration (CCHP) and quadrogeneration (CCHPI) or how much of mathematic is contain…
-MFra-
(To:jappelman)
Fred_Kohlhepp
23-Emerald I
(To:-MFra-)
will it solve with singular value decomposition?  (svd in Mathcad)
Even using svd2, you can not find the solution.
