Hello guys,
I am trying to solve a function with given find.
The point is, it works for a single value but not for an array of values.
I have attached the file. As you can see when defining a fix value than it will iterate to the new value. But if I want to find an array of solutions as function of RP and n than it won't start.
Is there a solution for this?
Kind regards,
Alex
The solution is to create user function on the base the Given-Find Block.
Alex Capel wrote:
Hello guys,
Kind regards,
Alex
Something along the lines of the attached?
Stuart
