Is it possible to define a formula using Global Definition and call the Results above the Where the Variable is defined, Please see the attached mathcad14 file.
Thanks in advance
Yes see attached. You have to define all variables using the global definition.
Mike
Mike
Thank you very much Mike, The Worksheet send to me is perfectly working, but in my worksheet not working ,Can you explain me any master settings in my MathCAD file or how?
You have not defined the letter C using a global definition in your worksheet.
Mike
