HELP WITH A GRAPH
Anousheh
HELP WITH A GRAPH
Please help me to plot the graph in the attached MathCad file.
Thanks for the time and help.
Anousheh
RichardJ
(To:Anousheh)
As Valery says, if you want to plot Y against X then either Y must be a function of X, in which case X must appear on the rhs of the function definition, or both X and Y must be functions of another variable that appears on the rhs of both function definitions (a parametric plot). I can plot
Y(X):=sin(X)
or
Y(A):=sin(A)
X(A):=cos(A)
but I cannot plot
Y(X):=sin(A)
I set yours up as a simple x-y plot, but it could also be done as a parametric plot.
10 REPLIES 10
If we have z(x, y):=... we must have x and y in right part of this operator of user function creating.
If we want to plot z(x. y) function we must at first check what returns this function:
x:=...
y:=...
f(x, y)=???
Thank you.
The left hand side of the function (equation) is simply: t/tau2. That is why I put it as T(t,tau2)
I need L/L0 on the y-axis and t/tau2 on the x-axis.
Thanks again.
Do you try to plot a parametric X-Y plot?
See http://twtmas.mpei.ac.ru/mas/Worksheets/curve2d.mcd
Thank you so much Dr. Valery Ochkov,
I have a simple equation:
t/tau2 = f(x,n,beta)
x=L/L0
L0=0.225
L=L0 to 1
n=4
beta=5
tau2=0.083
t=0 to 10
I need to plot x against t/tau2
Thanks again,
Anousheh
x=L/L0
L0=0.225
L=L0 to 1
n=4
beta=5
tau2=0.083
t=0 to 10
Thanks again,
Anousheh
beta:=5
tau2:=0.083
n:=4
L0:=0.225
f(x):=...
t(x) := f(x)*tau2
L:=L0 to 1
x:=L/L0
Etc
Hello valery,
Thanks again for your time.
For some reason, I am not able to do as per your instructions.
Would you please use the worksheet and plot the graph?
This is greatly appreciated.
Anousheh
Hello valery,
Anousheh
Anousheh!
I will glad to help you but I do not quit understand what do you wand plot.
Hello Valery,
Thanks again.
This is what I want:
Graph of L/L0 against t/tau2 for different values of n and beta.
Please see the MathCad file.
Thank you for your time and help.
Anousheh
RichardJ
(To:Anousheh)
Y(X):=sin(X)
or
Y(A):=sin(A)
X(A):=cos(A)
but I cannot plot
Y(X):=sin(A)
Thank you so much Gentlemen.
