See how operators work - "Conditional Operators" from the "Help Center": https://support.ptc.com/help/mathcad/r10.0/en/index.html#page/PTC_Mathcad_Help/conditional_operators.html
you have to define else branch for if command. See below.
Next time ... please upload your mcdx file.
Here's an alternative approach (notice that, for the x-values you use, the condition is always false):
Hi @DV_13990037,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
