Help to convert Mathcad 15 file (.xmcd) to Express 6.0 (.mcdx)
LL_9620477
2-Explorer
Could someone convert the attached file? Please, ASAP.
(To:LL_9620477)
Obviously you forgot to attach the file or something went wrong.
You can do the conversion yourself, though.
Download the latest Version of Mathcad 15 using one of those links
https://www.ptc.com/en/products/mathcad/free-trial/thank-you
http://download.ptc.com/products/mathcad/trial/mc15/Mathcad15_EN.zip
https://www.ptc.com/-/media/Files/Docs/Mathcad/Mathcad15-EN.zip
MC15 will work in full mode for 10 days and will then completely stop working!
On the other hand I think you will also need Prime to be in evaluation mode - I don't know if the converter in Prime still works after the trial period.
Anyway - if you manage to upload the file here, I'm sure someone will be willing to do the conversion for you.
Thank you. Please, see the file attached.
(To:LL_9620477)
Here is the converted file (Prime 6)
Since Prime is significantly less powerful than Mathcad, it will be necessary to revise the file. In particular, the two graphics on the last page.
Thank you so much!
