Help with using Region class and SelectedRegion property...
DavidDickinson
7-Bedrock
Good afternoon all,
While perusing through the MathCAD "Developers Reference", I came across a few things I think may help me and I need somone to explain and show an example or two...
First of all, the Region class states that it represents a MathCAD region within a Worksheet object, and that it contains information relating to its location on the MathCAD sheet. What I would like to know about this is, 2 things:
1. Can I see an example of how to use the Region Class, and what the proper syntax is? I searched through the "Developers Reference" and online, but came up with nothing...
2. Can someone explain what the Region2 class is and why it is used?
Secondly, I have a question regarding the selected region property: What is it, How is it used, and what is proper syntax for using it?
Thanks in advance to all! And PLEASE help me!
Hello!
Which version of Mathcad are you using?
Sorry, I am using MathCAD 15
The attached file contains some example scripted components. The file here:
Extra Components.mcd
Also contains an example. Search for "XML of a region".
