Hi ,
Can any one make the attached mathcad sheet normal. There are closely spaced vertical page lines . while printing small part of the shheets are only prining..
Thank you in advance for the help.
Best regards
Janardhan
??? Not sure what you mean.
The vertical lines indicate the page size.
You set up the page size, orientation and borders via "File" "Page Setup" from the menu.
Thank you.
Actually there was problem in system.
have ncie day
