How can I graph in this situation?
jlee-2
7-Bedrock
you can see a line in this picture.
I need to change data on the left side in a line.
this data is under a graph. lamda is changed depending on "theta"
it means that graph on the left side in a line will be changed because other data are applied.
I tried to apply it several times, but I failed contunally.. could you help me?
I want to graph automatically such as upper a picture.
This is picture that I graph manually.
6 REPLIES 6
(To:jlee-2)
I don't see any theta in the graph or in functions and arguments involved.
The argument of lamda seems to be some kind of velocity, the argument of lamda2 is an angle.
jlee-2
7-Bedrock
(To:Werner_E)
my graph indicate theta in CT2(v,0). 0 is theta.
"v" and "theta" are functions about CT2. I just expressed CT(v,0) becasue I want to graph a curve in case of CT(v,0)
the argument of lamda2 is an angle>>>you said
the argument of lamda2 is "theta"
I attached my file
(To:jlee-2)
This does not help determining what you are trying to do.
If you want lamda to change when theta changes, you have to make lambda dependent on theta, so lambda would be a function lambda(v, theta).
jlee-2
7-Bedrock
(To:Werner_E)
So Do you mean that I can't make automatically red curve??
(To:jlee-2)
I don't know as I don't know what we see in that red curve. But isn't it that what you wanted?
jlee-2
7-Bedrock
(To:Werner_E)
Yes, I want to be expressed red curve automatically.
