How can I make mathcad prime use different base units in calculations?
TS_9501702
So my starting parameters are P1= 7.5 kW and n1= 750 rpm.
On the left side Mathcad is converting my units to SI which messes with my final results.
For this formula I have to use P1 in kW and n in rpm, which mathcad is changing into W and revolution per second. Right side is how to calculation is supposed to be going by the formula.
Is there a way I can fix this? I saw that in Mathcad 15 you could define a custom unit system. Is there anything like that for Mathcad Prime?
Thank you!
(To:TS_9501702)
The formula you use has built-in correction factors (60/(2 pi) and 10^6) which are not necessary if you use units in Prime:
LucMeekes
(To:TS_9501702)
There is no custom unit feature in Prime. You're not the first to ask for/about it, and probably will not be the last.
So you've changed the unit of the Moment Mt1 from J to N*mm.
You should do the same with the P and the rotations: type a k before the W, and replace 1/s with rpm.
TS_9501702
(To:LucMeekes)
That one doesn't work. That is the point of the post 😄 I need Mathcad to use kW as base units
(To:TS_9501702)
Thank you!
Mathcad hasn't really messed with your units.  You need to tell it (effectively) that your base unit of time is the minute,
or, more specifically, ...
Stuart
