How do I FIND and REPLACE in prime 3.1 (What are the key strokes?). I want to use find and replace variables in Prime. Where is this functionality?
It's [CTRL-F] (as usual) and then you find the search and replace input boxes at the bottom of your Prime window.
You can also find this option at the bottom of the document.
Thanks.
Ah, those input boxes are there always, wasting vertical space on my screen, just as the ribbon is doing. No need to type [CTRL-F], but no way to get rid of 'em either...
