How to analysis portal frame
khaledEid
Hi I am trying to do a small sheet for portal frame analysis
is anything ready made for this task I can use I am referring to 2 hinged portal frame
Need a better explanation of what a portal frame is, maybe a picture?  And a description of what analysis you need.
what kind of analysis method do you want to use? classic or matrix method?
Hi all I am nearly done it using some forms ,not matrix Thanks Fred and Prramudiyanto
