Unfortunately Mathcad can't do what you demand.
BTW, the answer should NOT be v(s)/s - you should use a different name for the laplace transform of a function, maybe V(s)/s
So, MC can't solve these type of problems? Do you know of a program that can be used for something like this?
Thanks for your help.
I can't see a concrete problem. Mathcad can do it for concrete functions but unfortunately not for general integrals or derivatives. The latter is especially bad as it would mean manual copy/paste/substitution if you would use the laplace transform to solve an ODE symbolically.
Other programs which come to my mind are Mathematica and Maple or you may even use the free wolfram alpha:
http://www.wolframalpha.com/input/?i=laplacetransform%28int%28v%28t%29%2Ct%29%29
I am not sure about the free Maxima in that respect, you would have to give it a try.
I tried MATLAB but get this:
>> laplace(int(v,t), t, s)
ans =
v/s^2
I am not sure if I am entering the problem correctly. Any other way gives an error.
ans =
v/s^2
This is because v is treated as a constant. You get the same result with Mathcad
I am not well versed with Matlab, but did you try
syms f(t) s
laplace(int(f(t), t), t, s)
But then, as Mathcad and Matlab use the same symbolic engine (muPad), I would expect same results in both programs - so you would have to use a definite integral (see below).
You can get Mathcad to do the transform of the integral (nearly) the way you expected and retrospective it seems logical that you have to use a definite integral:
laplace(v(t),t,s) would have to be replaced with V(s) or something like that.
Its the same with a derivative
To solve an ODE you would have to replace laplace(v(t),t,s) by a variable, lets say V, solve for it and the use invlaplace
ML doesn't like that:
>> syms f(t) s
??? Error using ==> syms at 61
Not a valid variable name.
I also thought that it may be necessary to use a definite integral first.
I will try your last suggestion.
It works for the definite integral as it does for the derivative.
What annoys me is the fact, that I cannot make the replacement laplace(f(t),t,s)=F(s) automatically with substitute. Also it does not work to define a dummy function named laplace which returns a dummy variable because laplace() is a function of the symbolic processor, not of mathcad. The symbol processor which was used before it was changed for muPad ca. 6 years ago was Maple and could evaluate laplace(). For muPad it seems to be an empty placehoder function only.
So I cannot create a sheet for automatic ODE solution, I will always have to do the substitution manually ![]()
ad Matlab: http://stackoverflow.com/questions/5284457/how-to-find-laplace-of-intxt-t-0-t-in-matlab
That is good information in your link!
Yes, the trick in Matlab is to use muPad syntax directly. Matlab seems to allows this, but Mathcad not.
Up to version 11 of Mathcad you could use Maple syntax, too, when doing symbolics and could do some nice things which would not have been possible with plain Mathcad. They cancelled that with version 12 and Mathcad would not reach over undocumented commands to the symbol processor.
