How to calculate more than 18 floating point digits ?
yeet
I am trying to evaluate something but Mathcad 14 doesn't show it because it is very small, how can I view small numbers that are after 18th floating point digit ?
9 REPLIES 9
AlanStevens
(To:yeet)
Go to the Format menu. Select Result..., Tolerance, and set Zero threshold to a large number (maximum possible is 307).
Alan
Or so:
It is very useful! Why?!
Not exactly.
Shows the same value for each matrix element but I know that the elements should vary at 30th floating point or so ?
(To:yeet)
I am not sure if numeric calculation will give you the precision you are asking for, but symbolic evaluation could probably help:
yeet
(To:Werner_E)
It takes forever and still no result. Seeking for 'faster' ways than forever.
(To:yeet)
I don't think that numeric calculation will give you the disired precision in Mathcad - looks like you are limited to 17 significant digits.
Symbolic eval is rather slow as all precedings calculation have to be done using symbolics. So calculation time depends upon how your values were derived. And even with symbolic caclulation you may end up with rounding errors as the symbol proecessor switches to decimal mode automatically if only one single number in the whole calculation has a decimal point in it and there is no way to force it to exact mode.
StuartBruff
23-Emerald V
(To:yeet)
What are you trying to calculate? It may be possible to write some simple "big number" mul/add/sub/div functions that will address your particular problem in something less than eternity.
Stuart
MichaelH
(To:yeet)
And you know this how?
You can calculate to arbitrary decimal precision if you do addition, subtraction, multiplication, and division manually. I've attached a file that has small programs in Mathcad to do this.
MichaelH
(To:MichaelH)
The following graph shows the time required to complete the processing/calculation of pi (the file attached to the post above) vs. the number of digits.
As can be seen, the time grows exponentially with the number of digits. Using Mathcad for more than 3,000 digits of pi is impractical.
