In the same MATHCAD document, is it possible to have different headers (top page information, like date, title of calcul sheet, etc.) like Words for example? Thanks
It's in Mathcad, not in Prime (nor in Prime express), as so many other features, possibilities and functionality that Prime lacks in contrast to Mathcad.
If you (have no other option than to) use Prime, then you have to live with this limitation as well.
Note that Prime is a development newer than Mathcad version 15. The development being carried out by PTC means that a lot of items remain to be desired.
In Mathcad 11 you have these options for headers and footers:
As you can see, you can have a different header and footer for only the first page.
I expect that's the same up to Mathcad 15.
Where is this option ? I use MATHCAD express with my university program ?
I didn't found that option for header... can you help me ?
Thanks Luc,
