How to compute cubic roots using polyroots for continuous values
vveeran
Dear all,
Previously, I attached this file but I couldn't explained clearly in the worksheet.
Now, I updated the worksheet and explained clearly 'what to do? '.
I want to compute cubic roots using polyroots for continuous values (-84.948....20.136) for my example program
and also I need to plot real and imaginary values of polyroots.
I explained everything clearly in my worksheet which I attached below.
could someone help me in this.
Thanks.
(To:vveeran)
Maybe the attached file helps.
You have to turn the calculations into function depending on Vm (you doen't need "coeff" as you provide the coefficients yourself.
You should use a range variable only for plotting. To calculate a couple of values you shoul use a vector of Vm-values.
Not sure, but you may have to find a solution to cope with Mathcads habit of changing the order of the three roots depending on the real part (at least thats what I think it does) if thats not what you need and want.
Regards
Werner
(To:vveeran)
Regards
Werner
vveeran
(To:Werner_E)
Dear Werner,
Thank you for your  valuable comments.
It helped me a lot.
