I am having the equation as like this,
which I attached below.
How to find cube roots for this type of equation.
Please can anyone help me.
Thank you.
Use the polyroots function. ... providing you need a numeric solution and not an exact symbolic solution)
But, presentation might be something of an issue. That's 40^4 results each with 3 values ... how do you intend to organize their display?
Is this the modern-day equivalent of writing "I must not talk in class" a thousand times on the blackboard? ![]()
Stuart
Stuart
