How to convert XMCD file into MCDX format?
dkothia
The file is from Mathsoft MathCad, but I want to run it in the new PTC MathCad what is the solution please answer ASAP. And are the two software same?
202 REPLIES 202
Hi - Is it any way to delete the statement:
Created with PTC Mathcad Express. See www.mathcad.com for more information
when print or pdf the mcdx file.
Fred_Kohlhepp
23-Emerald I
(To:peyman)
probably not.
(To:peyman)
Sure!
If you think its worth the money, buy a license for the full version and that "branding" will be gone.
Other methods may require you to edit and modify the program file(s) but thats prohibited by the license agreement that you have accepted.
I have 19 MCD files that I want to read in MathCAD Xpress, can you convert all? when emailing back, please add .ALLOW to the filename at the end like: elliptic.zip.ALLOW otherwise system at LM will stop it.
Question, why did you make this complicated to read MCD files in Xpress? Can just have a simple utility on line to convert? Just curious why limiting usage of similar programs/ same company in purpose...!
Mano
LucMeekes
(To:ptc-4817179)
There's little to gain for you when these .mcd files would be converted to Prime format.
It will allow you to see the contents, but (at least some of them) you will not be able to use, because they contain Mathcad programs.
You are using Prime Express, which means that you can see these programs, but you cannot use (calculate with) them.
The reason PTC makes conversion so difficult is because they want to promote the usage of Prime, to sell the full edition of it. Prime express is free, so does not gain them any money directly.
Here it is (for Mathcad Prime 3.1 version).
Hi, can you convert this to mcdx, please
VladimirN
24-Ruby II
(To:Ned99)
Hi
Could you help me convert this file? Thanks.
VladimirN
24-Ruby II
(To:WeiXu)
Here it is.
Hi can you pls help me convert this in mathcad prime format?
Please find it in attachment.
Hey guys,
can someone help me to convert this file to be compatible with PTC Mathcad Prime 7.0.0.0?
I will be thankful. 🙂
You can find it in attachment.
TS_9662902
(To:VladimirN)
Thanks mate, have a nice day 🙂
MLabib
(To:ValeryOchkov)
May you please help me convert these files from .xmcd to.mcdx? Thank you!
LucMeekes
(To:MLabib)
Which version of Prime are you using?
VladimirN
24-Ruby II
(To:MLabib)
You can find it in attachment. For "97stm_v15" worksheet - you need to de-pass the closed areas.
MLabib
(To:VladimirN)
Thanks a lot! May you please also convert these two files for me? I use MathCAD Prime 7
MLabib
(To:MLabib)
VladimirN
24-Ruby II
(To:MLabib)
"97stm_v15" worksheet - still password protected.
VladimirN
24-Ruby II
(To:MLabib)
Here it is.
Is it possible to convert this file in mcdx please?
LucMeekes
(To:AB_10206795)
Yes, it's possible.
Ideally you should state which version of Prime you are/will be using.
Thanks a lot , the file has been made on mathcad 7.0 but i would like to use it on 6.0 or 8.0
Hi, Can you please help me convert these files, from XMCD to MCDX? Thanks!!!
LucMeekes
(To:KV_10325625)
Please specify which version of Prime you are using.
LucMeekes
(To:KV_10325625)
Attached. .mcdx files.
Привет,   может кто-нибудь, пожалуйста, помогите мне преобразовать эти файлы,
с XMCD на MCDX?
can you transfer this file for me, so it will be compatible with Prime 7.0?
Thanks, have a nice day 🙂
