How to convert XMCD file into MCDX format?
SK_10146432
2-Explorer
can anyone please convert this file to latest mathcad prime supporting file
LucMeekes
(To:SK_10146432)
Sorry, that's not what you want. You've attached an .xml file containing an error message from the convertor. I can convert it to Prime, but you'll only read the text of that error message.
I suppose you have a Mathcad 15 (or before) file  with the extension .xmcd or .mc that you want to have converted to Prime.
The latest version of Prime is version 7, and it has a built in converter that you should be able to use.
If you are NOT using the latest version of Prime, but version 6 or less, you have to have Mathcad 15 installed on the same computer for the converter to work. Note that Prime 6 and less CANNOT read a Prime 7 file, so you don't want the conversion to Prime 7 if you are on 6 or less.
If you still daren't or can't convert the file yourself, you have to do two things:
1. Attach your .mcd or .xmcd file.
2. Tell which version of Prime you use.
Then hope someone is willing to convert it for you.
Please attach your ".xmcd" worksheet to the message.
