How to force Mupad
FDS
How to force Mupad
First I want to apologize as I did send the same message 30 minutes ago but as I do not see it in the message list I am unsure whether it went through.
I would like to solve this equation (a*b+c*x^d)/(b+x^d)=y for x. In mathematica this went smoothly but not with Mupad (see worksheet). Could one of the more proficient Mupad users show me how I can force Mupad in giving me the same answer as mathematica?
10 REPLIES 10
LucMeekes
(To:FDS)
Mupad? This forum is on Mathcad and Prime!
Anyway. It might help if you tell the symbolic processor what type of variables a...d and y are: If they're positive, and/or real (rather than complex).
FDS
(To:LucMeekes)
Sorry Luc, I am using Mupad in Mathcad 15 (should have mentioned that).
LucMeekes
(To:FDS)
No problem.
This is what Mathcad 11 with the Maple symbolic engine produces:
FDS
(To:LucMeekes)
No surprise to me that MC11 with Maple solves it without issue (I am still missing my MC11 version). But is there any way I can obtain the same result with MC15? Adding simplify did not change much
Fred_Kohlhepp
23-Emerald I
(To:FDS)
This is not an answer, but it's as close as I could come:
-MFra-
(To:FDS)
Hi FDS,
(To:FDS)
The following study, using a simplified expression, may give you an idea of how muPad ticks. On contrary to Maple it defaults to domain complex and like the symbolics in older versions of Mathcad the assume modifier is not always achieving the desired effect.
Mupad seems to consider much more special cases in its calculations, it "knows" that powers are not defined in real domain for every combination of base and exponent, etc. and while this may be correct from a mathematical point of view it can be annoying in everyday use.
Maybe the problem is, that MuPad first was developed by university mathematicians. maybe the problem is, that Mathcad and Prime are using a very old and limited version of muPad. As muPad now is owned by Mathworks, owners of MatLab and a competitor of PTC  (really? can we still say that Mathcad Prime is a competitor of MatLab?) chances are low that symbolics in Prime will be enhanced in the near future.
(To:Werner_E)
This was as  closest as I could come with your equation:
-MFra-
(To:FDS)
FDS
(To:-MFra-)
Thank you all for your help! All explanations were much appreciated
