How to generate a best fit curve Z = aX^bY^c
nanay001
2-Explorer
I have a set of data which I divided into 3 vectors X, Y, and Z. I am trying to generate a best fit equation for this data based on the formula Z = a*X^b*Y^c
Is there a function in Mathcad to determine a best-fit equation based on the above formula.
This question was posted before, but was lost when the PTC Community forum got migrated into a new platform, so I am trying to get back the answers I obtained.
Felipe Loo
(To:nanay001)
Here are some suggestions as to how to achieve what you demanded for.
6 REPLIES 6
(To:nanay001)
You may have a look at the Mathcad function "genfit".
EDIT:: genfit will not work with 2 independent variables. The multidimensional analogon in Mathcad is "multidfit".
Or you could use a solve block with "minerr"
EDIT: I didn't look too closely at the type of your equation. Now that I did I guesss that Alan's suggestion below is the best appraoch. You may use "polyfit"/"polyfitc" to do so.
AlanStevens
(To:Werner_E)
Or take logs and use a linear fit.
Alan
Felipe Loo
Sorry, it will be not a curve but a surface.
Give please us please your 3 vectirs!
Felipe Loo
Send please please your 3 vectirs!
(To:nanay001)
