How to get Near Field From Far Field Antenna Pattern?
- November 3, 2011
- 2 replies
- 3966 views
I want to find the horizontal near field pattern of an antenna at a given distance in wavelengths from the horizontal far field antenna pattern.
I had to post this in Mathcad 15 since Mathcad 11 does not show negative radii in polar plots. But the txt file has the degrees in the first column and dB in the second column. (All the Matchad 15 doc does is display the antenna pattern on a polar plot.)
Anybody have a solution for doing this? I am trying to get an estimate of the isolation between two identical antennas spaced a given distance apart in wavelengths horizontally within the radiating near field.
Bill
