How to integrate correctly
sm�ller-2
Hallo,
i have a short question for how to write this integral correctly with vektorising.
At the moment its not working.
I need this vektorised because i have different loadcases ands different "xc" values.
Would be nice if anyone can help me
Thx best regards Stefan
7 REPLIES 7
also the other factors example "m" is different for every loadcase....
-MFra-
(To:sm�ller-2)
Hi Stefan, that's okay ?
Thx!
so you did the integration separatly without borders just the integral and then you calculatet the vektorising function with borders.
Hmm but why is my vektorising function not working i set the arrow over the hole formula.
Yes that does look correct the assume seems to be correct yes.
Best thx ill have a look on my sheet myself
You don't have to make everything a vector, if a value doesn't change, leave it a single value
THx for answers!
I could solve the problem!
Good day Stefan - glad you were able to find a solution!
The best way to get exposure to your question is to "Start a Discussion" rather than create a document.
Please let me know if I can ever be of help.
Best,
Toby
Thx for the help!
I will look for a discussion next time
Regards Stefan
