These examples are for each particular i:
But how to iterate through all values of i:
Maybe that way
If that ratio is all that is of interest, you should modify the function beta.in_out accordingly so that it only returns that ratio.
Another way could be to turn each of the "genfit" calls into a separate function of the index:
Maybe that way
Yes, the second variant.
But look:
How to extract each i from the above two vectors?
I don't understand what you are looking for!?
The values you calculate singly for i=4 and i=10 seem to match perfectly with the appropriate values in the calculated vectors.
I see no problem or error here.
Or could it be that you stumble across this age-old problem??
If that's the case you may have a second look at how I defined the vector(!) "ratios" in my answer above!!
Look:
I want to extract from the 20log() vector each i value:
Because look:
Compare the 2 vectors and you will see that they are different
So,
And from this vector I want to extract only the value corresponding to i=1:
Then if i=2:
And to put these values for each i into another vector:
@Cornel wrote:
Look:
?? See my edited answer above. Assign the 20log() expression to a variable so its a vector and access the appropriate element.
Or furmulate that expression as a function of i if thats more appropriate.
Not sure what you mean!? You use two different values for i. Of course you get two different vectors.
On the other hand I don't understand why you get vector like results anyway if you use a single scalar for i ??????
You should get something like
I used the sheet you posted last. The values are different so I guess you are using different data in your picture
I was expecting something like this to be in 20log() vector:
And so on...
I used the data and sheet you posted last and I have no idea where you would get these values from!?
When I do it, I get
and this perfectly corresponds with the first two values in the full vector we crated
Something is not updated accordingly...
Oooops!!
I'm very sorry but it looks like I mistakenly edited your post instead of replying to it!
So you can see my answer in the reply YOU posted -> https://community.ptc.com/t5/Mathcad/How-to-iterate-through-genfit-parameters/m-p/945065/highlight/true#M211414
Nevertheless, the question remains as to where the values in your pictures come from, which I cannot understand with your Excel data and the last prime sheet you posted.
