I am trying to keep everything - every equation and all the variables, etc. - in a single worksheet.
To do this, areas must be independent of each other.
Can MathCad do this? (I have version 15).
Thank you,
Anousheh
No. The nearest I think you can get to it is to define within a text region all of the items you would want in an Area. The ability to do what you want forms part of a long standing feature request to have rectangular (rather than worksheet-wide) Areas that are effectively embedded worksheets and can have their own local definitions - see, for example, http://communities.ptc.com/message/183988#183988.
Stuart
Stuart
Thank you for the information.
1- How do you define a rectangular area?
2- How do you insert a block of calculation into the text region?
Anousheh
You can't - it's a feature request.
ctrl-shft-a or Insert Math Region from the menu/insert or right-click context menu.
Have a look at the worksheet in the linked message.
Stuart
Thank you Stuart.
Anousheh
