I have imported an Excel file into Mathcad. I want to be able to change values in Excel and then those same values automatically update within Mathcad. I know you can do this with scripting, but I am not very good at writing code. I have attached the files to the discussion. Any help would be greatly appreciated.
See my answer (under a different user ID) from almost 12 years ago:
http://communities.ptc.com/message/39865#39865
(note my own reply to myself)
Maybe in another 12 years PTC will have given us the ability to link to the file directly ![]()
Use please the Properties (rright mouse click) and change regions in Excel sheet (A2:B4 etc) for inpot and output values.
Why do you think that this will make the mathcad sheet reflect changes made to the original Excel file?
